2.0 high compression pistons
I am looking for some good race pistons for 2.0 build. When mocking up the ones I have. We are only able to reach 10/1. I am looking for something to get me to 11.5/1.
What is a good source, or does someone possibly have something? thanks Scott |
Hi Scott - I'm sure that our community will be able to help you out with some; if you have any additional questions, please feel free to give us a call at 888-280-7799 and one of our Porsche reps. will be happy to assist you.
pistons
You may want to check your installed valve length as more than one valve job can change your compression quite a bit.Ciao Fred
compression ratio
You may want to check your installed valve length as more than one valve job will change your compression.Ciao Fred
| All times are GMT -8. The time now is 09:23 AM. |
