bcheney's Avatar
Chain tensioner housing cover: Gasket and sealant or only gasket?
When replacing the gasket on an the chain tensioner housing of a 3.2 engine do you only use the gasket or should some type of sealant be used on the mating surfaces in addition to the gasket? If sealant, what type should be used?
08 Cayenne V6
89 911 Targa Carrera 3.2
75 914-6 Conversion
Old 04-02-2018, 09:59 AM
bcheney's Avatar
Tensioner cover
Anyone?
08 Cayenne V6
75 914-6 Conversion
Old 04-03-2018, 07:31 PM
PrimeMvr's Avatar
I use Curil-T on both sides of the gasket. Not sure if it's necessary but no leaks for me on several rebuilds.
87 930 - Black - 3.4L/964 cams/K29/Powerhaus IC/6AL-2/B&B dual exhaust/MTX-L/235-315 Toyo R888/18" Kinesis wheels/Big Red brakes/LSD
10 997.2 Cab - Speed Yellow
83 SC Cab - Guards Red [SOLD]
17 NSX - Nouvelle Blue
Old 04-03-2018, 07:56 PM
Mine had sealant on both sides and no leaks. I will copy that method on reassembly.
This is a good thread.
The Complete Engine Sealant Thread...
https://r.tapatalk.com/shareLink?share_fid=844&share_tid=284737&share_pid=2606548&url=https%3A%2F%2Fforums%2Epelicanparts%2Ecom%2Fsh owthread%2Ephp%3Fp%3D2606548&share_type=t
Sent from my iPhone while Driving
Derrick
Old 04-03-2018, 09:37 PM
Alan L's Avatar
I've done them without sealant - no probs. But I use the thicker gaskets. If you had the paper type, I think I would use something. That will work, without sealant, as long as you have both surfaces really clean - I mean really clean, no warps and no previous leaks. Why not use a sealant? No real reason - except less clean up next time you pull the cover off.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 04-03-2018, 11:48 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
My absolute favorite sealant for paper gaskets is Permatex Copper Spray-a-Gasket. Apply a couple of light coats to both sides and of course, to a clean and oil free surface and you are good to go. I also have used it on 915 transmission paper gaskets. It too, like my engine, is still dry 8 years later. And should you have to disassemble, it comes apart without drama and removing the Spray a Gasket is a breeze with acetone or the like.
1986 Targa Guards Red
2021 MT09 SP
Old 04-04-2018, 04:08 AM
Just the paper is fine. Curil T if you must. Not a leak prone area.
Old 04-04-2018, 08:02 AM
K&W spray coppercoat for me.
206 637 4071
Old 04-04-2018, 08:47 AM
Ingenieur
How do they come from the factory? It seems that they do not use sealer. Most of the gasket will pull away from either the cover or the housing, leaving an as machined surface. Some places do stick sometimes though, so I do not think it is correct to call them just paper gaskets. They seem to come treated with something. Why add more?
Old 04-04-2018, 09:15 AM
VFR750's Avatar
Interesting. Many different ways. I have used locktite 574 on both sides of the paper gaskets. No leaks.
When installed dry, I had leaks.
My data suggests that 36 year old housings and covers need a little extra sealing help.
Old 04-04-2018, 04:58 PM
Thinking more about the topic, it's also a good idea to check the flatness of the covers. I have a piece of 5/8" thick plate glass with 220 or finer emery sandpaper glued on. I use it to ensure the covers are flat by moving them back and forth on the plate to correct any warping. Before I started they certainly weren't flat but after 5 minutes or so of effort on my cheapo flatplate, they were in good order. The valve covers received the same treatment and no, they weren't flat either.
2021 MT09 SP
Old 04-04-2018, 05:29 PM
I do the low corners because that’s where the oil will pool when not running or on the right, always a pool.
Bruce
Old 04-05-2018, 05:03 AM
