-   -   962 Two Valve Chamber Volume (http://forums.pelicanparts.com/911-engine-rebuilding-forum/990911-962-two-valve-chamber-volume.html)
Speedy Squirrel 03-18-2018 09:49 AM
I am investigating a 95mm bore turbo motor with improved or-ignition characteristics. One option is the 962 combustion chamber. I mocked on up using the photo in Bruce Anderson’s book.
http://forums.pelicanparts.com/uploa...1521391482.jpg
I measured the chamber volume to be 84.8. The normal chamber volume was 92.7.
http://forums.pelicanparts.com/uploa...1521391598.jpg
With a flat top piston and a clearance volume of 3.2, that gives a 7:1 compression ratio. I was shooting for 8, so I will have to tinker some more.
Daugaard 03-19-2018 01:05 PM
It seems that you can insert material on both sides of the valves
http://forums.pelicanparts.com/911-engine-rebuilding-forum/619651-bathtube-combustion-chambers.html
Daugaard
stownsen914 03-19-2018 01:44 PM
I believe this was done for a very specific use case - improving combustion characteristics on a racing turbo motor that was at the time limited by the rules to single ignition. I'd think dual ignition would be a much better solution in most cases.
Scott
Speedy Squirrel 03-21-2018 03:18 AM
Interesting! Thanks for the link. I am going to tinker some more this week with it.
Going with a turbo motor compression ratio of around 8 makes this an achievable goal. If you add too much material it shrouds the valves and effects the port flow.
Daugaard
Speedy Squirrel 03-21-2018 03:26 AM
Well, they had their reasons, and I have mine!
Seriously though, the corporate “we” looked at a lot of variations like this when designing the modern Hemi. In the end they wound up with both! They needed the dual plugs for a smooth idle and low emissions, and the squish area for knock resistance.
Scott
stownsen914 03-21-2018 08:00 AM
Interesting. Can you fit the shrouding and a second plug? Or somehow shroud both sides of the combustion chamber? Sounds like some interesting experimentation.
[Edit] Read the posts linked above, and see that it has been done before. I wonder what the performance advantages are. I'd think there are easier ways to raise compression with custom pistons, but the reduced combustion chamber might yield some power that high compression pistons cannot?
MBruns 03-21-2018 08:35 AM
heads
I have a set of those single plug, single turbo heads from a 934, It was the engine that Wayne Baker won Sebring overall in the school bus car. we have most everything to put that engine back together.
Mike Bruns
Speedy Squirrel 03-22-2018 08:17 AM
I think I need those!
Mike Bruns
Speedy Squirrel 03-30-2018 02:52 PM
I have filled in some more on the spark plug side. This arrangement yields around 7.5 compression ratio.
http://forums.pelicanparts.com/uploa...1522446539.jpg
Here is photo of the current Dodge Hellcat chamber for comparison.
http://forums.pelicanparts.com/uploa...1522446642.jpg
Does anyone have a damaged head I could buy to practice the welding and heat treating procedure?
Henry Schmidt 03-31-2018 08:31 PM
We built/welded a set of "peanut" heads for a 2.5 engine that made 11:1 compression using 2.7 (8.5:1) RS pistons. Short stroke and all.
Bill at Extreme Cylinder Head flow tested the heads and felt "shrouding" was not an issue.
Our thought was to have him replicate this design in a billet head but never pulled the trigger.
http://forums.pelicanparts.com/uploa...1522553185.jpg
http://forums.pelicanparts.com/uploa...1522553203.jpg
I probably have a damaged head you can have.
Speedy Squirrel 04-03-2018 08:45 AM
Outstanding! That’s the way to do it, or even 10:1 with a flat top piston. I bet that thing had a nice torque curve.
Apparently, the effect on valve shrouding is overrated. The current Hemi Head (Apache) is pretty similar:
http://forums.pelicanparts.com/uploa...1522770018.jpg
Thanks so much. I will take you up on your generous head offer. I will message you to work out the details.
