-   -   Some specs needed (http://forums.pelicanparts.com/911-engine-rebuilding-forum/99227-some-specs-needed.html)
farleyd 02-22-2003 10:16 AM
Some specs needed
Hi, i am rebuilding my 2.7 to 2.7RS specs minus the MFI, using Webers.
Id need the specs of the following:
angle for 3-angle valve job
valve seat specs
valve measurements (tolerance) specs
Thanks!
jgparker 02-22-2003 12:04 PM
valve seat angles: 30,45,75
valve seat specs: 1.5+/-0.1mm contact surface, and
47.5mm valve stem end to shim cavity length
valve specs: (head diameter, stem diameter, length)
intake: 46+/-0.1mm, 8.97-0.012mm, 114+/-0.1mm
exhaust: 40+/-0.1mm, 8.95-0.012mm, 113.5+/-0.1mm
I don't have the head margin spec handy.
