-   -   missing at high RPM's (http://forums.pelicanparts.com/911-engine-rebuilding-forum/99317-missing-high-rpms.html)
Robert Sanchez 02-23-2003 06:16 AM
I have recently completed a clutch kit replacement at home on my 911 3.2 1984. It all looks good until I tested at high RPM ( more than 5000 rpm's) I find that it is missing only when it gets to 5000rpm's and higher. I checked the spark plugs for correct gap, I took the valve covers off and checked the engine studs to see if any were loose or fractured, I checked fuel presure because I replaced the filter, I checked the compresion and it's OK. Do you have an advice on what may be causing the missing at high rpm's?
Bob:confused:
ChrisBennet 02-24-2003 07:44 AM
Bad plug wires can have that effect. Have you checked them in the dark for the telltale light show?
-Chris
Robert Sanchez 02-24-2003 09:03 AM
Thanks for your advice, I will try that tonight and let you know.http://www.pelicanparts.com/support/smileys/read.gif
Robert Sanchez 02-26-2003 01:54 PM
:( Noppp, no sparks at night. Still have not figued out the problem. CAN ANY BODY PLEASE GIVE ME MORE IDEAS!!!
THANKS
al lkosmal 03-02-2003 12:23 PM
Hi,
I had the same symptoms with my 77S. My coil went out shortly afterwards. Replaced it and the problem went away. Do you have another coil to try??
Al
