3.2 engine rebuilding questions
Hello all,
I have an 85 911 with 265,000 miles on the engine. The thing still runs strong but it burns some oil and smokes on startup. It has started to smoke even after warm-up lately. I would like to start my engine rebuild fund and want to get an idea of what I should be expecting for a budget. I'd like to budget for a rebuild with simple performance upgrades so maybe cam regrind, euro spec pistons and exhaust? I have some engine rebuilding experience but this is my first 911. I'd like to rebuild this engine myself to save money and for the experience. I'd appreciate experts estimate on an expected budget and advice on performance upgrades. Also, I live in California so I need to keep in mind smog inspections. Thank you, Jason
1955 VW oval window ragtop 1971 & 1974Triumph Bonneville 1985 Porsche Carrera 2013 Toyota Tacoma TRD 2016 Triumph Speed Triple R |
The car. I love it.
Hi
Most of us beginnner should get this book , help to save time .money ,motor up grade. how to tear down , ect How to Rebuild and Modify Porsche 911 Engines Book Part #: BK-135124 Last edited by frankoporsche; 04-07-2018 at 01:41 AM.. |
Book is fantastic. A must have.
Thanks for the responses. I do have the book along with the Bentley manual. It says a typical budget is $6000 for a basic rebuild but that was for a 2.7l. Does that amount still apply to a 3.2 with performance upgrades?
Everything is near the same price across the board, 2.0 to 3.6. Valves and new P&Cs vary.
Bruce |
Under the radar
Wayne's book does have a page on the individual pricing of parts and repairs. That is a good starting point.
If you want to do it right, you are probably going to send most of your parts out for cleaning, inspection, and repairs or machine work. On a high mileage motor like yours, you can figure it is going to need everything done. The good news is, the 3,2 motors will not usually need any case work, like the 2,7s. If you are REALLY lucky, and you have Mahle cylinders, and they are in spec they can be reused. That is a stretch on a high mileage 3,2, however. Otherwise, figure on new or refurbished cylinders. The good news is it isn't much more expensive to go to a 3,4 using bored cylinders. Also, it is possible to have your cams reground to 964 specs. Don't forget to replace those pesky divilar studs.
Really appreciate the replies and the confirmation on budget. I'm planning on starting the rebuild next year so that gives me time to build up my bank account and do some more research.
Thanks again, Jason
Its pretty easy to burn through $10k in parts and machine work. And all the monetary values in Wayne's book are pre-bubble pricing. Expect to pay double if not triple the values quoted.
based on my experience I would recommend you consider doing only the heads ans see if that doesn't cure the smoking issue. I found little to nothing wrong when I did my 80SC. Lower mileage at 110 000 miles or so. But I imagine it would have been fine another 10 years without splitting case. My cylinders&pistons were as new.
80SC (ex California) |
I then took the car to our local Porsche dealership and had the "official" Porsche mechanics go over it to compare the findings. They too found leaks. In their words "highly unlikely" and "remote" chances of a fire resulting from the few drops they found. The said, "drive it and enjoy it for now but eventually, you will need to address the leaks in the distant future when it is due." They were nice enough to give me the official Porsche quote to rebuild the top end $16,112!!!!! Yikes. That's an expensive toy I've got in the garage. |
Under the radar
$16K? What are those guys charging per hour?
Tom Feeney 1970 911 T 1973 911 T Looking for engine 6103643 |
steve 911T SWB..
so cam choice and what has to be replaced (in case) for the euro spec pistons ... will follow the theat with a lot of interest steve |
I would agree with this post - depending on what you need to replace. Just finished a 2.7 rebuild and costs are going up. Used both Ollies and Supertec for different things - the learning experience was well worth the cost - love my car now - this was a racing engine so many more upgrades to cams/rods/case etc. Go for it - you'll love it.
