-   -   Valve guide question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/994719-valve-guide-question.html)
jellonailer 04-25-2018 01:30 PM
Looks like my machine shop had a little trouble with one of my valve guides. What would you do?
http://forums.pelicanparts.com/uploa...1524688227.jpg
Flat6pac 04-25-2018 05:49 PM
It’s not going to bypass oil or cause excess wear, I d run it
Bruce
DSPTurtle 04-25-2018 06:44 PM
Request that they redo it. I'd be surprised if that showed up at my door from my machinist.
Ken911 04-25-2018 06:58 PM
That flange has a pretty good divot in it. You should address that before bolting the headers on.
jellonailer 04-26-2018 11:13 AM
Thanks. My thought was to check it myself. Its a chance that it was cosmetic on the outer surface. That said, I agree that it should not have left his place like that and will let him know.
Good eye on the divot in the flange. I will take a close look at that too.
Appreciate the great comments.
Ken911 04-27-2018 08:00 AM
Actually on mine the guides were installed then it was cnc ported that part of the guide was milled off. So as long as the valve clearance is ok. It might look bad but is most likely ok.
porschetub 04-29-2018 03:35 PM
Looks like on old guide to me...not a new one.
racing97 04-30-2018 07:47 AM
I can see by the picture some nicks at the end of the guide if someone blocked off, which I see they did the air injection port they may have dressed as it entered the port and nicked the guide with the burr.
regards
