2.25 S weber settings with DC 40 cams
Hi
Q1: does anyone have recommendations for 40IDA3C for 2.2L S e.g., 85mm Carillo CP S pistons (9.8:1), John Dougherty DC40 cam, ported intake manifold opened for S, ported and larger S valve in heads by Craig Garrett. I am starting with 34 145, 52, 70 F26. 5 degrees of advance. 3.2 pounds of pressure, all floats correct. All shafts tight.
Performanceoriented 1quickS table lists 2 2.2 911S settings and (E) is missing. Which S one do you think is correct? I have been told that 32 is more correct than 34 as well. This setup runs great at 2200 and up rpm, but a 1 degree less rotation of the idle speed setting to reduce the engine idle speed causes the engine to stop. This is the first time I have experienced this simple problem where I cannot get a good setting to make it idle.
Looking for anybody who has built this engine or something really close to this.
thanks Marlin
Marlin Ness
sadly no longer: 1967 912, 1971 911T, 1974 911 Targa, 1975 914, 1972 914 Eagle GT with V8
currently: 1972 914 Eagle GT with 3.2 Carrera, 1970 911T (964 turbo wide body look), 1986 911 Carrera
Old 04-30-2018, 07:32 PM
2.2
I would try a 55 idle jet.
Old 05-01-2018, 04:44 AM
ok, will try that.
Anybody have insights on no idling at all when the butterflies are closed? I should be able to get it to idle.
thanks
Marlin
Marlin Ness
Old 05-02-2018, 04:15 AM
Under the radar
Trackrash's Avatar
My 2,5SS used 32 vents, 135 mains, 170 airs with F3 imulsions and 65 idles. 170 rwhp with E cams.
I could not get my carbs to work with 55 idles.
Once you get the motor running you MUST either have it dinoed or get an A/F gauge to verify your settings.
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-07-2018, 09:20 AM
