-   -   Temperature when Driving (http://forums.pelicanparts.com/911-engine-rebuilding-forum/995789-temperature-when-driving.html)
den912 05-06-2018 01:59 PM
Had my original 6 engine totally rebuilt too a 2.2 with E cams ,when the car is up to temperature the temp gauge looks quite high as in the picture below,I’ve been told by another member that’s how there car runs,when sat in traffic the temp goes up a bit more as in the first pic ,is the car running to hot and what if anything should I do
http://forums.pelicanparts.com/uploa...1525640220.jpg
Thanks Brian
Trakrat 05-07-2018 08:39 AM
well.. this depends. What's the temperature outside??
What sort of driving are you doing.. stop n go.. highway?
Do you have an oil cooler? aftermarket? original? if so.. does the fan kick on?
is your engine shroud properly setup and the fan turning properly?
How many blades are on your fan? I've heard that on older cars, updating to a newer style fan blade can help improve cooling.
I've also heard that certain oils will run hotter than others.
Trackrash 05-07-2018 09:37 AM
What car is it in? What gauge is that? What sender are you using? What is your intake? Carbs?
I would use an IR thermometer on the oil tank to see what your oil temp is.
porschetub 05-07-2018 05:42 PM
Indicates you are running hot,checked my spare gauge insert which has the increments shown right @ the top of the insert ,you need to turn the whole gauge to see it,mine is a 911 insert and your gauge appears to be 914 or 914/6 ,don't know if these marks are there on those inserts.
However looks like you are atleast running 120C which is bloody hot,is your sender ok,I go new on these cause its cheap insurance.
Good luck.
