-Kav. |
Cheers. -Kav. |
Kav,
Sorry to hear about your father. I know that/this is a difficult time as I lost my mother two weeks ago. Keep up the great work, it appears your Dad was proud of you and the work you've on the Cannery so far. Paul |
Kav, sorry for your loss, it is never easy . Maybe you can decide that your dad lives on through the joy you get from interacting with the Canary. Take the time to be in tune with your emotions and freely express them . I love your project
Ian |
Kav
Sorry for your loss and Godspeed to your dad. I lost my mom and dad some years and I think of them constantly. I'd like to personally thank you for sticking with this and I know there are tons of people like me who are very appreciative of the time and effort you've put into this thread and hope you will continue. Tony |
Longblock
With the valve clearance checked I can seal up the longblock.
I made a little video of the process: <iframe width="853" height="480" src="https://www.youtube.com/embed/VfPWd2pCZVY" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> Appling the Loctite 574 to the cam housings http://forums.pelicanparts.com/uploa...1562944514.JPG Torqued down the cam housing and then the heads. http://forums.pelicanparts.com/uploa...1562944514.JPG Chain housings installed. http://forums.pelicanparts.com/uploa...1562944514.JPG Curil-T on the camshaft housing end plates. http://forums.pelicanparts.com/uploa...1562944514.JPG Thrust washer, shims, woodruff key, sprocket flange, cam sprockets and idler arms. http://forums.pelicanparts.com/uploa...1562944514.JPG I set the timing again to 3.15mm for the E-cam. http://forums.pelicanparts.com/uploa...1562944514.JPG Priming the hydraulic chain tensioners http://forums.pelicanparts.com/uploa...1562944514.JPG I decided to upgrade to Supertec's bronze idler arm bushings, I had to check the timing again http://forums.pelicanparts.com/uploa...1562944514.JPG Installed on the right side. (new o-ring not in this picture) http://forums.pelicanparts.com/uploa...1562944514.JPG Chain housing covers installed. http://forums.pelicanparts.com/uploa...1562944514.JPG |
I sent my distributor to Kurt at Partskassik, he gave it a service and installed new points, rotor and cap.
http://forums.pelicanparts.com/uploa...1562996346.JPG Installed all the rockers and adjusted the valves http://forums.pelicanparts.com/uploa...1562996346.JPG From TDC working my way around the firing order 1-6-2-4-3-5 http://forums.pelicanparts.com/uploa...1562996346.JPG New Spark plugs http://forums.pelicanparts.com/uploa...1562996346.JPG New turbo lower valve covers and original uppers with the Porsche lettering sanded out http://forums.pelicanparts.com/uploa...1562996346.JPG Oil cooler was pressure tested and hot tank dipped, a few bent fins.... http://forums.pelicanparts.com/uploa...1562996346.JPG Sump plate, oil adapter etc. http://forums.pelicanparts.com/uploa...1562996346.JPG The completed longblock! http://forums.pelicanparts.com/uploa...1562996346.jpg Cheers! -Kav |
Very nice, look forward to seeing it run!
Nice, Kav!
Awesome as always Kav
This is still one of my favorite videos to watch. I'll never understand why there aren't more videos out there showing all the steps needed to build these engines?
I have a 3.2 and I've been putting off rebuilding my engine because I just don't feel confident yet in doing this by myself. If I had a step-by-step instructional video that was complete and showed each and every process, I'd have my engine completed by now. |
Thanks Trakrat. Me too, there are a few video but not a series showing every step in detail. I think I’ve cut mine down to the bare minimum. I have tried not to leave anything out even if it gets a bit boring but I thought that was important.
Hope this helps in spurring you on to get your 3.2 done! Cheers -Kav |
Kav, a couple questions, hard to tell from your rocker arm picture, but there are two points to watch for. The end of the rocker shaft should always be flush with the end of the narrow casting boss,(lay a spare shaft over the rocker and you'll see how it needs to center) and the 5 MM end of the shaft bolt should always be towards the middle of the engine, never towards either end of the engine. Once all the tin and cooler is on you would not be able to access that 5 MM end for service.
Good work Kav thanks for sharing.
Henry |
Weber Triple Barrel Carburetor Teardown
My Weber 40 IDTP 3C1 triple barrel carburetors have been sitting patiently on the shelf for a few years. It's time I rebuild / upgrade them. I plan on cleaning them up, plating certain parts and upgrading the jets etc for my higher compression engine.
The Webers are the U.S. emissions version "40 IDTP 3C1" very much like the '40 IDA 3C" but with slightly different progression ports and jetting. I can do something about the jetting and may 'convert' them to IDA's if the throttle shafts need re-bushing but I will only know for sure when I run them on the car so ..... Here goes.... wish me luck. I made a little video of the process: <iframe width="853" height="480" src="https://www.youtube.com/embed/D_sam1XdFMQ" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> Quite the mess. http://forums.pelicanparts.com/uploa...1571975107.JPG Dirt and grime all over. http://forums.pelicanparts.com/uploa...1571975107.JPG Intake Manifolds removed. http://forums.pelicanparts.com/uploa...1571975107.JPG Air boxes and Velocity Stacks removed. http://forums.pelicanparts.com/uploa...1571975107.JPG A quick clean in the parts washer before I do more teardown so I keep the dirt out of the passageways. http://forums.pelicanparts.com/uploa...1571975107.JPG Removing the tops ready to strip them down all the way. http://forums.pelicanparts.com/uploa...1571975107.JPG The carb stripped down. http://forums.pelicanparts.com/uploa...1571975107.JPG The parts I'll send out for plating. http://forums.pelicanparts.com/uploa...1571975107.JPG Everything organized per carb in these little compartment trays. http://forums.pelicanparts.com/uploa...1571975107.JPG Cheers. -Kav. |
Awesome documentation in your video and your posts here on the board. So sorry about your father.
David |
Hi, Kav -
I rebuilt my 2.7 10.5:1 twin-plug last Winter. Watching your wonderful videos on your engine build was a warm recollection for me. I might add that I used my surface plate and sand paper on every surface that needs to keep oil in the engine, particularly the chain housings and the surface on the case. 2000 miles and no leaks, other than the fact that I am learning how to use the silicone valve cover gaskets. My friends that does lots of engines swears by them. He says 35 in-lb. on the nuts and he has never had a leak! - Rob |
Dennis |
Weber Triple Barrel Carburetor Rebuild
The parts are in and it's time to rebuild the Weber 40 IDTP 3C1 triple barrel carburetors (I hope I can remember where everything goes....)
I made a little video of the process: <iframe width="853" height="480" src="https://www.youtube.com/embed/SU1oHn0LMWA" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> Everything laid out and ready to go. http://forums.pelicanparts.com/uploa...1582389929.JPG All the parts and new jets etc. http://forums.pelicanparts.com/uploa...1582389683.JPG The plating turned out great! http://forums.pelicanparts.com/uploa...1582389683.JPG Cleaned out all the passages with carb cleaner and nylon brushes etc. http://forums.pelicanparts.com/uploa...1582389683.JPG installing the floats and setting them to the right height in the chamber. http://forums.pelicanparts.com/uploa...1582389683.JPG Installing the chokes, I've gone too big I know it (34mm). I have 30mm coming. http://forums.pelicanparts.com/uploa...1582389683.JPG The body of the carb complete. http://forums.pelicanparts.com/uploa...1582389683.JPG The new velocity stacks look great! Shame to cover them up! http://forums.pelicanparts.com/uploa...1582389683.JPG The before shot. http://forums.pelicanparts.com/uploa...1582389683.JPG The after. I'm very happy with the way they turned out! http://forums.pelicanparts.com/uploa...1582389683.JPG Cheers. -Kav. |
Nice work, Kav. The carbs look great. Who did you use for your plating?
dho |
Tru6 Restoration & Design Cheers, -Kav. |
