-   -   Removing head from cylinders (http://forums.pelicanparts.com/911-engine-rebuilding-forum/997534-removing-head-cylinders.html)
iamchappy 05-24-2018 12:25 PM
I am disassembling a 78 3.0 the 4-5-6 head with a little wiggling lifted straight off with the washers, the other side 1-2-3 seems to be stuck and held on by the washers, i was able to get 4 washers on the sides free but the inner headstud washers dont want to budge, any suggestions or tricks to free up those washers so i can lift the head off.
strictly 05-24-2018 12:47 PM
Copper hammer, just dont hit the fins, a few taps both sides near the manifolds bosses should free it
jpnovak 05-24-2018 12:55 PM
I use a wood drift and deadblow hammer to knock them loose. Often the issue is 574 on the alignment pins causing them to stick.
Flat6pac 05-24-2018 03:55 PM
The oil return tubes hold the heads to the cylinder too.
Bruce
