-   -   911 Engine test stand (http://forums.pelicanparts.com/911-engine-rebuilding-forum/997686-911-engine-test-stand.html)
Emo993 05-26-2018 03:23 AM
Would like to build an engine test stand. Any good picture of what you have or like. Thanks, Mark
mepstein 05-27-2018 05:45 PM
If you do a search there are probably a half dozen examples already listed.
Emo993 05-28-2018 05:38 AM
Yup, did that. Did not see any thing I liked. Best, Mark
florio 05-31-2018 01:50 PM
oh well, here's mine:
Hi, I guess "it depends": mine is super simple, just to make sure the engine runs and do some basic tuning of the MFI and the throttle linkages. It helped me identify a small leak from a base cylinder gasket, and also some ageing brings on the oil console.
It's basically just a recouped frame fixture onto which the rear mounting bolts are secured. I even use long threaded rods to raise, lower and adjust the engine height. The ancillary components (electrics, pump, oil tank) are just secured with screws and some scrap metal.
Here are some pics:
http://forums.pelicanparts.com/uploa...1527799457.jpg
Here is a link to the video of it running:
https://youtu.be/xQ4XsnzMCiE
I'm setting it up again this weekend, so I can send more details if you want
Happy tinkering, and show us what you come up with!
Dario
