LinkBack | Thread Tools | Rate Thread |
Removing Cylinder Ring Gasket 82 911 SC
I had no issuer myself. Could you try with a high pressure cleaner (water). Might get wet and maybe not even work but no risk of damaging
80SC (ex California) 3.2SS |
I just use the small screwdriver and distort the aluminum ring.
A set of needle nose will pull it right out Then use a pick to clean the seal recess of deposits. Bruce |
A little tiny screwdriver did the trick, they were quite gooped in as a result of the broken head studs. I used a shop rag as a cantilever to avoid the screwdriver contacting anything but the ring. So much for the "proper tool" seal remover. Thanks Bruce
Thread Tools | |
Rate This Thread | |
