Harpo's Avatar
upgraded oil pump
I'm under impression that a 964 oil pump would be a good upgrade for my 3.0L. If this is correct is $400 a good price? What should I be looking for problem wise? Are there any case modifications required to make the 964 pump fit/work
Thanks again
Old 06-13-2018, 04:26 PM
The pump, used, many times are worn out, that’s the reason to have them for sale
Before spending the money I would have it checked by Supertec or one of the others
Bruce
Old 06-13-2018, 07:42 PM
Harpo's Avatar
Thanks, I just sent supertech an email to see what they recommend
Old 06-14-2018, 04:16 AM
Puny Bird
Mark Henry's Avatar
I just used my 3.0 pump, it's a three rib so it's a pretty good pump.
Some think it contains magic smoke, to me it's a pretty simple pump. I tore it down, made sure it didn't have any FOD, blueprinted it as it had .012" endplay so it now has about .0015-.002" endplay both sides. Then I cleaned up some flashing for better flow, made sure the pick up tube is in good.
The last thing I did was to DFL coat the inside of the pump body, I do this in house as I'm a engine builder.
Then back together, some locktite on the studs, packed it with assembly lube for fast priming and installed it. I have perfect oil pressure.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 06-14-2018, 04:29 PM
