-   -   dumb question on max compression ratio (http://forums.pelicanparts.com/911-engine-rebuilding-forum/999356-dumb-question-max-compression-ratio.html)
Harpo 06-12-2018 05:02 PM
Good evening Pelican
What is the highest CR on a single plug with pump gas?
Thank you
chrismorse 06-12-2018 06:54 PM
It Depends...
Fuel octane ratings vary. here in kalifoania, 92 is about it and that is with alcohol. We cannot buy "pure" gas unless we swear a blood oath, in writing, that such criminal fuel will NEVER be used on the highway.
did someone get bought off on that one???
To a lesser extent, it depends on the cam duration, overlap and the ability of the engine to go over 100% volumetric efficiency, (dynamic compression).
Still pissed off,
chris
racing97 06-12-2018 07:39 PM
10:1
Schmierung 06-12-2018 08:57 PM
10.5:1 with carbs and, most importantly, S + cams. The overlap reduces the dynamic compression. Single plug.
In MI, you may be able to get away with milder cams. My euro 3.0 has SC equivalent cams stock and 9.8:1 stock, pump gas, single plug.
Harpo 06-13-2018 03:53 AM
I'm still on the fence weather I want carbs or ITB. I have absolutely no idea about what Cams I want other than I have no intention on racing so nothing too aggressive.
safe 06-13-2018 07:13 AM
Well tuned carbs vs well tuned ITB / EFI:
https://www.youtube.com/watch?v=aj-Z33MO2Gk
Quite interesting.
