View Single Post
Jeff NJ Jeff NJ is online now
Jeff NJ's Avatar
Boosted, like Sir On his Knees said, what you are adjusting with the pill is when it enriches. You also need to adjust how much it enriches when it does hit that RPM. Yours seems to be set too lean. I actually had to lean mine out a bit from how the Leask Wur was sent to me, and I have also put a 4800rpm pill in as it will go too rich if I don't. Weird, I know, but the datalogging says I'm fine at WOT all the way to redline in the 11.8 to 12.0 range.
I've tried leaner at cruise, but my motor likes to run rich and you can feel it doesn't like it if I am over 14ish.
1988 930 Venetian Blue
Old 07-05-2017, 06:33 PM
