Pelican Parts Technical BBS
Pelican Parts Technical BBS (http://forums.pelicanparts.com/)
-   BMW 1 Series (http://forums.pelicanparts.com/bmw-1-series/)
-   -   135is gear selection problem (http://forums.pelicanparts.com/bmw-1-series/976896-135is-gear-selection-problem.html)
ybslo 11-07-2017 12:37 PM
2013 7 speed - 135is - won't allow to me select Drive from Park without shifting into Reverse first. Anyone ever hear of this?
Once in a while it will go into drive - of course while depressing the brake pedal and the button on the side of the shifter- but at least 9 times out of ten it will not allow the selector to engage drive. Always works if you go to reverse first, so no issue backing out of the garage and then pulling it down to drive (foot on brake - not necessary to push button on side of shifter). But from Park, you must select Reverse first.
No faults displayed or showing with Bavarian Technic.
Thanks for any ideas.
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website
