Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
In memory of Warren Hall (Early S Man), 1950 - 2008.
[Click for more details]
banner
BMW 318i engine squeal
1995 318i engine noise, loud squeal after the engine warms up.
Yesterday I replaced the water pump, belts, and tension pulley. Started the engine and after it warmed up the noise is back. I then ran the engine without the AC belt, still squealed. Took the tension off the belt for the alternator, power steering, started the engine and it still squealed. I believe I eliminated all accessories, the noise seems to be in the inside of the engine, it does seem to go away a bit when the engine is revved up. Would this be the bearings in side of the engine? Under the valve cover or main bearings on the crank shaft? Would a low or no oil pressure cause it from lack of lubrication?
Engine has 220k miles on it. Am I looking at a whole engine replacement?
Advice on engine replacement?
I did change out the automatic transmission at 198K by myself, not sure if I want to take on an engine replacement. Transmission was a big task.
Can you pull engine and transmission out together?
Thanks,
Paul
Old 11-16-2011, 07:29 AM
  Recommend this thread for the PelicanWiki    #1 (permalink)
Mike Holbrook
Could be a tensioner in the serpentine belt going south.
You do know you are posting this in the Porsche 911 section, right....
Mike Holbrook
Meridian, ID
1979 911SC Targa
Old 11-16-2011, 07:32 AM
  Recommend this thread for the PelicanWiki    #2 (permalink)
Put a Porsche engine in it.
Or a small block chevy.....
On my 2002 I always pull the engine/gearbox together.
97 2.5 Boxster
78 911SC 9118300015
65 911 301368
65 912 450355
'76 BMW 2002 (SCCA ITB racer)
Old 11-16-2011, 07:40 AM
  Recommend this thread for the PelicanWiki    #3 (permalink)
FWIW, BMW motronic 318i motors use an internal chain to turn the cam and distributor. There is no serpentine belt like a 325 six cylinder motor.
It's a descendent of the 2 liter 2002 and 1981 and later 1.8 liter 320i CIS motors.
Great simple and easy to work on motors too.
Old 11-16-2011, 09:35 AM
  Recommend this thread for the PelicanWiki    #4 (permalink)
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
