-   BMW 3-Series E30 (-1991) and Earlier... (http://forums.pelicanparts.com/bmw-3-series-e30-1991-earlier/)
-   -   E46 330i engine in to E30 318i (http://forums.pelicanparts.com/bmw-3-series-e30-1991-earlier/945262-e46-330i-engine-e30-318i.html)
Papagotty (guest) 02-08-2017 09:47 AM
Ok so I have a 1994 318i. I've pulled the motor and dropping in a motor from a 2001 330i. I realize I need a new pedal with electronic potonsiometer. Will the pedal assembly from the e46 plug and play.?i also realize I will have to do some wire spicing from old harness to new harness. And driveshaft will need customizing. Exhaust etc. Anything else you might think of would be a big help.
This post was auto-generated based upon a question asked on our tech article page here: BMW E46 Throttle Housing Replacement | BMW 325i (2001-2005), BMW 325Xi (2001-2005), BMW 325Ci (2001-2006), BMW 325ti (2001-2004) | Pelican Technical Article
Casey at Pelican Parts 02-08-2017 09:47 AM
I would try to adapt the 330i engine to an earlier throttle cable type engine management system, then adapt the E30 cable to connect to the throttle body, you will lose a little bit in diameter but in that car power should not be a big issue! I will create a post in our forums and hopefully another member can help out. Sounds like a very cool project!
- Casey
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
