Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E30 (-1991) and Earlier...
LinkBack Thread Tools Rating: Thread Rating: 2 votes, 1.00 average.
Papagotty (guest)
Guest
Posts: n/a
Ok so I have a 1994 318i. I've pulled the motor and dropping in a motor from a 2001 330i. I realize I need a new pedal with electronic potonsiometer. Will the pedal assembly from the e46 plug and play.?i also realize I will have to do some wire spicing from old harness to new harness. And driveshaft will need customizing. Exhaust etc. Anything else you might think of would be a big help.
This post was auto-generated based upon a question asked on our tech article page here: BMW E46 Throttle Housing Replacement | BMW 325i (2001-2005), BMW 325Xi (2001-2005), BMW 325Ci (2001-2006), BMW 325ti (2001-2004) | Pelican Technical Article
Old 02-08-2017, 08:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #1 (permalink)
I would try to adapt the 330i engine to an earlier throttle cable type engine management system, then adapt the E30 cable to connect to the throttle body, you will lose a little bit in diameter but in that car power should not be a big issue! I will create a post in our forums and hopefully another member can help out. Sounds like a very cool project!
- Casey
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #2 (permalink)
