Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
E46 330d touring crank but no start(no ground at DDE relay)
Afternoon guys, hate to start with this big of a problem but here goes. any help would be great. i have a 2000 330d Touring, i done an auto to manual swap on it recently and it will not start, just cranks and cranks. When ignition is turned on the heat gauge goes straight to max and communication with DDE via diagnostic machine is impossible. After some testing i found the DDE relay is not being activated because there is no ground signal coming from DDE but when relay is in place it outputs 12 volts on the ground wire. i am so confused, any help would be greatly appreciated.
Sent from my SM-G930F using Tapatalk
Old 08-27-2019, 08:08 AM
