-   BMW 3-Series E46 (1999-2005) (http://forums.pelicanparts.com/bmw-3-series-e46-1999-2005/)
-   -   ghost problem (http://forums.pelicanparts.com/bmw-3-series-e46-1999-2005/123482-ghost-problem.html)
Jared at Pelican Parts 08-22-2003 11:05 AM
Ok, that seems strange, as I dont believe that the A/C Compressor would cause any of the problems you were describing..
Eli at Pelican Parts 08-22-2003 11:06 AM
Finally. . .
Something that they probably should have been able to detect sooner.
Yes, I would also have to agree with Jared on this one. . . smells like fish.
http://www.pelicanparts.com/support/smileys/yltype.gif
Jared at Pelican Parts 08-22-2003 11:09 AM
I would ask to see the old compressor and have them explain to you exactly what is wrong with it. It sounds like they are fixing things that dont need to be fixed. The A/C Compressor would not cause the car to buck and die at idle.
1999 323i 08-22-2003 11:13 AM
I asked him why it didn't show an error and he told me that the computor would detecet that
Jared at Pelican Parts 08-22-2003 11:16 AM
Ask him to explain to you exactly how the compressor affects the running of the engine.
Eli at Pelican Parts 08-22-2003 11:24 AM
Just my Opinion
What were they doing?????
The only thing I can think of is a very defective clutch on the compressor or a seized compressor. But you should be able to verify this by spinning the old one.
Who knows, I think something is wrong with this picture. . .
Just my opinion here.
1999 323i 08-22-2003 04:28 PM
I picked up the car they washed it filled it with gas, and didn't charge me one dime. OK cool, but I got no explaintion of anything they did, the service man just looked at me and said just take it! it seams to be running ok but after driving that 535 for a month I was spoiled. I drove it to the Acura Dealership and traded it. I guess I will never know what really went wrong to the car. Thanks to everybody here for your help and happy motoring
Eli at Pelican Parts 08-22-2003 05:11 PM
Good Luck
Should you ever wish to return to turn back, we'll be here waiting....!
1999 323i 08-22-2003 05:22 PM
Jared at Pelican Parts 08-25-2003 08:31 AM
Sounds like the dealership got cuaght in a lie or something and didnt want to be held liable, hence not charging you. I think that in this instance, trading the car might be the right thing to do. I would be suspcicious of the dealer, and I personally would not have left until they explained exactly what was wrong with the car. By law, the dealership has to explain to you what work was done and they have to show you the parts they replaced.
1999 323i 08-26-2003 04:47 AM
I know your right, but I just wanted to go on with my life and the real **** of it is I only had 8 payments to go and would have paid off
1999 323i 08-26-2003 04:48 AM
been*
Eli at Pelican Parts 08-26-2003 07:45 AM
Pictures for all
In keeping with tradition you now have post a picture of your new ride.
1999 323i 08-27-2003 06:06 AM
ok
1999 323i 08-30-2003 09:07 AM
I just pick up my new tsx, Its not even close to a BMW , If I could work on a car I would have kept it, pic so to follow
Eli at Pelican Parts 09-02-2003 07:52 AM
When you say "not even close" what do you mean?
1999 323i 09-06-2003 06:54 AM
First thing is the way the doors sound when you close them. they sound hollow tinny, Second it feels lighter in the stering feed back its just not that wonderful feeling the 3 gave me. Third the txs 4 banger is a high rever, but its not the same smooth six. The gear box and 6 gears are great short clean shifts, but it is not as heavy or refinded FEELING as the 3 is.
Eli at Pelican Parts 09-08-2003 09:21 AM
You can always come back.....
With that being said. . . you're always welcome back....
I'm sure in the next 6 months or so I will be looking to sell my M3 to try and pick up an M3 or M5 2000-2003. We'll see how things go until then. I only have 52K on mine, I'm trying to rack the miles on the Jag in the mean-time.
http://forums.pelicanparts.com/uploa...1063041643.jpg
David 06-17-2004 03:26 PM
I've got a 99 323i that stumbles and acts like it's going to stall at idle when the A/C is on. I checked the fault codes and got a misfire code for all 6 cylinders. Obviously this sounds exactly like the problem here. I want to see if anyone else is having this problem before I spring for a new A/C compressor. This sounds like a weird fix for a misfire problem.
EDIT: More info: After clearing the fault codes, my wife drove the car for several days without running the A/C. I checked for fault codes and found none. I just drove the car with the A/C on and now there are the same 6 misfire fault codes.
I went by the dealer and asked them about the problem, they said it was probably the coils. So I asked what are the odds of all six coils going out at the same time, they said it happens. Sounds to me like they're clueless.
