-   BMW 3-Series E46 (1999-2005) (http://forums.pelicanparts.com/bmw-3-series-e46-1999-2005/)
-   -   Clunking noise in suspension? HELP ME DIAGNOSE PLEASE. (http://forums.pelicanparts.com/bmw-3-series-e46-1999-2005/152261-clunking-noise-suspension-help-me-diagnose-please.html)
jbripps 03-07-2004 02:28 PM
Hi all,
Just finished a brake job, and noticed that my front passenger side wheel had some movement and play when I was taking the wheel off. When I got inside, I noticed that the bottom joint (not sure what it's called, but it does have a small sleeve on it) was loose? Attempted to tighten, but didn't want to tighten any further.
Also, I do notice a small clunking when I hit bumps slowly from that side. Anyone know what the fix would be? I do not have a part diagram, so anyone that could post one would be appreciated.
regards
BMWCowboy 03-11-2004 05:31 PM
Thats the frt control arm>>has to be replaced >>BOTH sides!
With the frt control arm bushings.
Jeron 03-12-2004 07:14 AM
You might look into aftermarket urethane bushings. Urethane with make the ride slightly more rough but the steering should feel more precise.
Also, I beleive that you can either buy the entire bushing assembly or save money by replacing just the bushing in the existing assembly. Replacing the bushing alone requires more time and a special tool.]
Here it is the featured article: http://www.e46fanatics.com/
http://www.e46fanatics.com/features/feature.php?news_id=40
Have fun researching.
Jeron
p.s. I found a mention of a recall on the bushings. You check it out.
Jared at Pelican Parts 03-12-2004 02:26 PM
Front Control arm..
Replace it IMMEDIATLEY
jbripps 03-12-2004 06:05 PM
If I get the control arm piece, are all of the bushings included in the assembly. How easy or difficult is the DIY?
thanks,
BMWCowboy 03-13-2004 10:40 AM
Not real easy 2 replace>>U have to have either a special tool or an air hammer to remove control arm>>the bushings should come with the new arms>>If not they are kinda hard to squeeze on>>I use alot of lube & a pry bar to pry them on :)
Jeron 03-15-2004 08:02 AM
Why does the control arm need to be replaced? Are there non-seviceable parts attached? Or is it just cheaper/easier to replace the whole thing?
Jeron
BMWCowboy 03-15-2004 03:39 PM
The control arm attaches in 3 places>>one being the bushing.....if only the bushing is worn thru then you can just replace the bushings>>if not the whole arm has to be replaced>>its one whole peice
BMWCowboy 03-15-2004 03:44 PM
On the E-46 the old style bushings are only lasting about 45 to 60,000 miles :( >>>the new bushings are very thick and havnt seen any go bad yet :)
hcoles 06-02-2017 07:10 AM
This is an old thread but I have a "new" way to remove the old FCAB's. The first one I pounded on for about an hour and finally got it off. The second one I put a pipe wrench on the sleeve of the bushing part and rotated it slightly while spraying in a bit of white grease at the "top" so the grease would flow down in between the rubber and end of the arm. After about 2 complete turns while pulling down the bushing came off after about 5-10 minutes. I cleaned the treads in the car and the bolts and added Blue Loctite and torqued to 44 ft-lbs. The bushing are the HD type that are supposed to last longer. Not a great design IMO. If I have to replace again I'll get the urethane (or whatever they are) ones.
