Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
Question cold start
My car is a 2000 323i w/a 57k miles. I live in Chicago. Every morning im experiencing cold start problem, my car would start with no problem but after 15-20 secs you can feel it would shake a little and check engine would illuminate. Before it would happen in a temperature 20 degrees below, but this morning its listed 50 degrees outside to my surprised it happened again. Usually if this happen. What i would do, i will turn the ignition off and turn it on again. The car would start fine with no problem and no check engine illumination.
I brought my car to the dealership last 3 wks. ago because of this problem. They test the car on the computer to check and run check engine codes. They said, theres is a mis fire on cylinder 1 and 4, they check the coils and plugs and told me that there in nominal condtion. They swap coil 1 to 3 and 4 to 6 and according to them check engine (mis fire) codes clear off. They also check my battery and acoording to them its still okay.
For a while the car starts gud in a cold winter morning. But, after two weeks im back to my cold start problem again. Today its 50 degrees outside i start the car and boom after 15-20 seconds the car would shake a little and check engine would illuminate and same as usuall, if i turn off the ignition and start the car again the car would start fine with no shaking and no check engine.
Anyone, experiencing the same problem? Please help....I don't have a code reader.
I already change my spark plugs with NGK's, fuel filter, air filter and cleaned my injectors with red line fuel injectors.
Im planning to do some upgrades ( 17" wheels n tires, konis udjustable, H&R sport springs, ECIS cone intake, shark injector and supersprint exchaust) but im stuck until all issues has been resolve.
orics
orics
Old 02-07-2005, 06:22 AM
Sounds like eng temp sensor is going bad--> had one in the shop 2day but it left a sensor fault-->not misfire???
Old 02-09-2005, 05:12 PM
what do you think about the ignition coil problem? I heard that they kind of problematic especially with the E46 models. I know sometimes there going bad or fail very soon. Some change them with only 7k miles.
Which one is the original equipment the BREMIS or the BOSCH? I heard the BREMIS are bad and BOSCH are ok? Any inputs????
orics
Old 02-22-2005, 04:58 PM
there are two style bremi's. the first style, bosch doesn't make a replacement for. the later, bosch does make a replacement for. when available go with bosch. also, replace all 6 of them, and the tower between the coil and plug too.
1991 nissan 240sx
sr20det cp pistons, eagle rods, 740cc inj, k3t turbo, jwt s4 cams, lots of duct tape, GReddy headgasket
Old 03-18-2005, 08:22 AM
