Ummm...Setting the Clock
Yes, I do not know how to set the clock. Since the clocks have now changed I'm an hour late wherever I go! Please - can someone tell me how - 2001 330xi
Thankshttp://forums.pelicanparts.com/uploa...1116444804.jpg |
IIRC, twist one of the sticks by the odometer while the clock is showing on the dash. It will set the dash clock AND the radio clock simultaneously.
Just looked it up. Twist knob on the right with key on. To switch 12hr and 24h press the knob. Would you like a pdf of your manual for reference? It is 2mb I can email it. |
sweet i have been wondering the same thing thanks
I hate to resurrect a new thread, but I simply cannot change the clock on my girlfriends' 2002 325ci. The problem is that the clock does not display on the dash, only the radio. So there is no way to change the time. So I guess the question is, how do I get the clock to display on the dash? I've cycled through the modes, but never can find it.
Yes, this clock setting procedure is in the manual, but not how to display the clock on the dash. WTF????!! |
The turn signal stalk on the left has a push button on the end that cycles through the temp, clock, mpg etc. Are you saying this never goes to the clock?
I don't recall if we tried that, but I will check that tonight and let you know...
Yes, that turn signal stalk did work. Thanks, I guess we just missed that one.
Glad it worked out. Thanks for posting the outcome.
