ABS Fault Codes
Hello all, I have a 1996 328i with abs fault codes 14, 17, 177. I have replaced both abs relays with no luck. Checked all fuses with no luck. Does someone have a chart showing the meaning of the fault codes?
Thanks, John:confused: |
ABS light flashing rapidly
If you get any information on your fault codes let me know. My 2002 330CI just began flashing the ABS light rapidly when the ignition is on. Funny my service book says it should stay on constantly, but it doesn't mention a rapid flash.
Did you get your fault codes from a code reader? Which one?? |
| All times are GMT -8. The time now is 11:18 PM. |
