Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
ejames19's Avatar
Rocker Panels?????
Have rust issue on driver side rocker, where in the world can you find a replacement panel????I have checked many, many sites and cannot find anything to find out cost. Very frustrating. Have 1999 328i, help......
'No illusion is more crucial than the illusion that great success & money buy you immunity from the common ills of mankind, such as cars that won't start.'
'81 911SC Coupe
'03 MDX
'00 328i
Old 12-18-2007, 02:38 PM
rocker?
is this an e36 or e 46 body style? doesn't it have a urethane cover over the metal rocker panel? so is the metal under the cover rusted? if the metal panel is rusted it could be repaired or replaced by a local auto body shop. this part may only be available from a dealer or wrecking yard. the wrecking yard should sell you the part for a fraction of the dealer cost, but will require more labor to install. i own an auto body shop in Portland or, i can ive you approx cost of this repair if needed, but i need more details. you can try car-part.com to locate used parts nationwide.
Old 12-22-2007, 09:43 PM
