Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
Cordts's Avatar
OBD Code PO128 Thermostat Question
Is it at all possible that the thermostat is ok and the temp sensor on the upper radiator hose is bad?? The temp meter reads normal...
1967S Porsche Targa #500317S EURO
1972 BMW 2002Tii
1967 Triumph TR4a Irs
1967 Austin Healey "Bugeye" Sprite
1966 Austin Healey 3000 MKIII
Old 07-07-2009, 04:43 PM
Talking
Here is the way I think it works,
Your computer expects the engine temp to rise at a given rate. With a working Thermostat the temp gain is predictable. I would think there are other inputs used to triangulate the thermostat's pass / fail outcome.
Bottom line is the engine should reach operating temp quickly in its usual way. If it takes longer for the engine to reach operating temp the code will trigger.
What does your temp gauge read after 5 minutes from a cold start ? Assuming you don't live in the north pole LOL
Old 08-03-2009, 10:19 PM
Banned
Send a message via ICQ to LockDr816 Send a message via AIM to LockDr816 Send a message via Yahoo to LockDr816 Send a message via Skype™ to LockDr816
After warm up, feel the top and bottom radiator hoses. If the top one is considerably cooler than the bottom, the impellor in your water pump may be spinning freely on the shaft. Just had that problem on one of my father's cars.
Old 08-03-2009, 10:33 PM
Cordts's Avatar
New thermostat assembly fixed the problem..
1972 BMW 2002Tii
Old 09-21-2009, 11:41 AM
