-   BMW 3-Series E46 (1999-2005) (http://forums.pelicanparts.com/bmw-3-series-e46-1999-2005/)
-   -   A/C Leak Troubleshooting (http://forums.pelicanparts.com/bmw-3-series-e46-1999-2005/691573-c-leak-troubleshooting.html)
ef330xi 07-29-2012 09:47 AM
I have a 2005 330xi, and I'm experiencing warm air from the passenger A/C and slightly cooled A/C on the driver A/C. After searching various BMW websites and YouTube, I found and did a recharge of the system with a small can of R134A. The pressure was below the recommended level based on the outside temp. After this, the A/C did work well on both sides.
However, after 3-4 weeks, I'm back to the same spot. (warm on the passenger side, and slightly cooled on the driver side).
After additional research, I've read it's a good thing to change the Schrader values in both the High and Low pressure sides. I've seen a tool on YouTube that allows this process to be down without discharging the whole system.
Some, here are my questions:
- Can just the values be replaced, or do I need the whole part (64-509-177-577)?
- Is there a tool for replacing this for my car?
- Is there a specific valve needed? Some videos show numerous size values.
- Are there other troubleshooting suggestions? Or, do I need to have the system checked at the dealer :(.
Thanks in Advance
Ed
Manolito 07-29-2012 08:26 PM
You can get a kit with an ultraviolet flash light and ultraviolet dye that you add to the refrigerant that will help you to locate the leak. Sorry. but I am not familiar with replacing Schrader valves.
