Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
Pressure in expansion tank
I have a 2001 325I and every time I open up the expansion tank cap to check the fluid level I get pressure coming out from it. Is this normal because it's a close system?
Old 07-03-2014, 06:49 AM
You need to read some basic auto maintenance manuals, or at least your owner's manual.
YES there will be pressure in a cooling system when it is hot. It can blow out boiling water and seriously hurt you if you remove the cap when it is hot.
Old 07-24-2014, 06:18 AM
