-   BMW 3-Series E46 (1999-2005) (http://forums.pelicanparts.com/bmw-3-series-e46-1999-2005/)
-   -   Error code po340? (http://forums.pelicanparts.com/bmw-3-series-e46-1999-2005/830437-error-code-po340.html)
mackdesign 09-18-2014 05:46 PM
Error code po340?
1999 323i, 140K. Car idles smooth but began accelerating very slowly. Got the error code PO340. I replaced the intake cam position sensor with no change. Thought I may gave gotten a bad sensor so I swapped it with a friends that I know was working correctly. Still no change, error po340 and no acceleration. What do I check next? Any help appreciatedhttp://forums.pelicanparts.com/uploa...1411087537.jpg
Manolito 09-23-2014 06:21 AM
These cars are noted for getting corrosion in the plugs to the VANOS sensors, but after unplugging it twice, the connection should be fresh and clean. Is the wire intact (not pinched when the valve cover or water pump were being replaced)?
Does your car have the original VANOS O-rings? At 16 years of age and 140k miles, it is due if they have not been replaced.
One of my e36s had a lot of varnish build up in the VANOS that kept it from moving freely. That varnish was extremely difficult to remove. Nothing would dissolve it. It had to be polished off.
