Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
BMW.E46's Avatar
Please Help!!!
Ive only had my bmw 325i about a month and a half and for that amount of time i have found that i love it! Recently ive been hearing this whining noise at idle thats driving me up the walls. As i accelerate the noise seems to change with how hard im accelerating. It starts out as a whine and changes to a screeching noise at higher rpms, the guys on e46 forum dont know so im hoping someone on here will. https://plus.google.com/104416842017162986909/posts/ZYR5YJH5XUm
Sent from my SM-G925P using Tapatalk
Old 02-07-2016, 06:28 PM
mechanic
Hi I got this BMW in the customer call me and sad that he got home from work and changed his shirt and went to start the car and it didn't start (crank) battery voltage is 12.56 lights on dash ok I am suspecting the KEY EWS 3 SYSTEM has anyone had this problem before how can I test it he only has one key since he bought the car used any help will be appreciated thank you I have worked on American cars and Asian many years but I'am not well familiarized to much with europeo cars and I want to learn
Old 02-08-2016, 09:49 AM
Whine and Screeching Noise
Check the belt tensioners
Randy
2000 323i
Old 02-20-2016, 01:46 PM
Administrator
Luccia at Pelican Parts's Avatar
I agree, I'd check over bearings. Good images of pulleys at figure 1 here - BMW E46 Alternator Replacement | BMW 325i (2001-2005), BMW 325Xi (2001-2005), BMW 325Ci (2001-2006), BMW 325ti (2001-2004) | Pelican Technical Article
Would you say you hear it through your speakers or it's very apparent it's coming from the engine bay?
Old 02-29-2016, 01:34 PM
Probably the tensioner pulleys, take the drive belt off and see if the bearings are gone - loose and/or noisy when you spin the pulleys.
If its not these then maybe check the o ring in the radiator top hose - give the top hose a squeeze and seek if any coolant drips out. If it does its likely to drip onto the drive belt at the water pump/crankshaft pulleys. In sufficient quantities it can lubricate the belt and cause it the slip and squeal at high RPM.
Old 03-01-2016, 10:08 AM
