Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
Check engine light
2001 325ci keep getting MAF sensor and misfire codes , the light usually comes on at idle .Bad MAF or vacuum leak.
Old 12-17-2017, 06:53 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hello and welcome to the forum! What are the codes that keep popping up? Have you replaced the MAF?
Old 12-18-2017, 10:26 AM
check enigne light
EE, Misfire Cyl.#1,FO Misfire Cyl.#3,EFMisfife Cyl.#2,CA 02sensor control limitCyl.#1-3,E302 sensor adaptation limit Cyl.1-3,08 Air Mass Sensor. In that order. Have not replaced the MAF yet.
Old 12-21-2017, 05:51 AM
Administrator
Eric at Pelican Parts's Avatar
It's very possible your intake boots are ripped, causing these error codes.
Check out this tech article: Air Intake Ducts Replacement
I'd probably simple and start with checking the intake ducts for tears, since it doesn't cost you money. If there aren't any rips or tears in any of the boots, I'd probably do a MAF cleaning. If that doesn't work, maybe a replacement MAF.
17 Macan GTS
97 240SX
94 Land Cruiser
Too many Miata's to count.
Old 12-21-2017, 05:24 PM
