Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
Stompie
Hi guys,i have a problem with my BMW320d e46 2005 model.my only key is worn out and my steering has locked.cannot get steering lock off and can not turn ignition at all. I have had 2 different locksmiths out to unlock with no luck.what now?
Old 01-04-2018, 09:09 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hello and welcome to the forum! Take a look at the link below to a DIY tech article on the issue that you're having. Hope this helps you and best of luck!
https://www.pelicanparts.com/BMW/techarticles/BMW-3-Series-E46/89-BODY-Ignition_Lock_Cylinder_Replacement/89-BODY-Ignition_Lock_Cylinder_Replacement.htm
Old 01-04-2018, 01:53 PM
