Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
Help please
I got this code P0705 it says indicates a fault in the transmission range sensor electrical circuit (PRNDL INPUT) for a predetermined period of time. Please what can I do
Old 04-08-2018, 10:40 PM
Administrator
Dmitry at Pelican Parts's Avatar
Hello - below is some useful info that I found in regards to the E46 platform and the P0705 code:
It's an easy part replacement: 3C Gearbox switch (P0705), part# 24-10-7-507-818.
It's #9 (position switch) in this diagram from RealOEM: A5S325Z HOUSING WITH MOUNTING PARTS.
It's suggested to replace it right away - if ignored it for several days, you may not be able to start the car - if your scan tool can reset codes, you can DIY it.
Give us a call at 888-280-7799 and one of our BMW part specialists can help you out with the part.
Old 04-09-2018, 02:19 PM
