Order Online or Call:
888-280-7799
HACKER SAFE certified sites prevent over 99.9% of hacker crime.
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Click Here To Add Your Car to Our Owner's Photo Gallery!!!
Chat with other Users in the Chat Room NOW!!!
banner
The Pelican Parts Forums salutes the memory of Warren Hall (Early S Man), 1950 - 2008.  You will be missed by all... [Click for more details]
How to install new pulleys/tensioner on e46 (year 2000, 323i)
i have a question regarding how to install 2 new pulleys on an e46, year 2000, 323i model with manual transmission.
1. How do i know if i have a hydraulic tensioner VS a mechanical one?
2. ASSUMING i have a hydraulic tensioner, then i would need to purchase two pulleys (the black small plastic wheels, not the big metal ones) one for the A/C and one for the Water pump/power steering. both pulleys are the same and the part number is 11-28-1-748-131-M40 (Adjusting Pulley, used on A/C Belt, Water Pump/Alternator Belt, Center Mounting, For Models with Hydraulic Tensioner). so my question is how do i change these two pulleys? do i need to remove the whole pulley assembly out or can i just change the two small black plastic pulleys while their assembly are still attached to the motor?
3. do i need any special tools for removing the pulleys?
i did change the belts recently and i dont think it's too hard to change the idler pulley but i have no idea how to change the other two's.
thanks a lot.
Old 05-10-2009, 09:22 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
I have never done my e46 yet, but a quick look at the parts book indicates that they are substantially similar to the e36s.
What they call a hydraulic tensioner looks like a little miniature shock absorber with a coil spring inside. The pulley for that has a centered hole.
What they call a mechanical tensioner appears to have a spiral spring in it (like a watch spring). The pulley for that has an offset.
I have never replaced a tensioner, just the pulleys, and one of my e36s has 250k miles on it.
Old 05-10-2009, 09:44 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
thanks for the reply. when i removed my belts i turned both A/C and Water Pump tensioners clockwise and it sounded like it there were springs inside the tensioners. I looked at my tensioner and i didnt see any miniature shock absorber so i think i have mechanical tensioners.
thanks for the info.
Old 05-11-2009, 06:55 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
You have a shock pulley at the bottom it has a nut to remove tension also the top pulley has a center nut I just use that and remove tension the top one.
Old 05-25-2009, 10:51 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.1
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright 2009 Pelican Parts - Posts may be archived for display on the Pelican Parts Website
One of the largest message boards on the web !
