Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E90 (2006-2012)
access to bolt at rear of Valve cover
Hello,
can anyone share some trick for removlng\disconnecting breather hose at rear of valve cover I'm trying to remove. I prevents me from getting out the last bolt in back. 2008 328I coupe(E92?).
want to change my gasket( oil leaking) changed oil filter housing and this is next
kinda stuck at this point so appreciate any help I can get.
Thanks in advance
Old 03-17-2019, 06:35 PM
On the N54 the cowl filter tray and wiring brackets have to be removed / disconnected. Then you can get to it . We have a single bolt there .
Old 03-17-2019, 10:16 PM
I just replaced my valve cover. That was the hardest part of the job. I finally did it with my fingers. I just read a hint to put a hose clamp around the ring to release it from the notch. There is a great you tube video by fcp euro. Look it up, it really helped me.
Old 05-21-2020, 05:55 PM
