Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E90 (2006-2012)
E90 N55 Temperature Gauge Not Working
I have a 2011 E90 N55 and the analog temp gauge is not reading temps.
I am working through typical issues with this 140K car.
Replaced the valve cover gasket, alternator, radiator.
To try and fix temp problem I replaced the sensor on the front of the oil filter but this did not fix it. I read this is simply a switch in any event. From some research I saw this may be a sensor on the oil pan and it is common to see it fail, or stop sending if the car sees severe weather driving like driving in snow. I read replacement requires draining the oil. Car runs well otherwise.
Again this is the analog temp gauge on the dash.
Old 11-30-2023, 09:36 AM
Administrator
Matt at Pelican Parts's Avatar
As in engine temp? I believe it may be linked to the sensor on one of the coolant hoses. It's pretty easy to spot
Old 12-01-2023, 12:54 PM
Banned
I agree with this
Old 12-09-2023, 03:25 PM
Tags
engine , gauge , sensor , temperature
