2008 BMW 328i HEATER HOSE to upper radiator hose
HELLO I think my o-ring might have fallen out..should there be one in the bottom heater hose that connects to the middle bottom of upper RADIATOR HOSE???
THE CLIPS ARE ON THERE.. ![]() someone said u can replace with DORMAN part 627-002 meant for AUDI but they said it works on BMW..anyone with INFO ..please message me... is this heater hose that connects to UPPER RADIATOR HOSE SUPPOSE TO HAVE AN ORING?? anyone know what size???THANKS |
Administrator
If you are referring to the O-ring inside the hose, you're really better off just buying a new hose. There is generally a reason you cannot replace just the O-ring. Many have tried but often still end up with a leak.
