Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E90 (2006-2012)
Author of "101 Projects"
Wayne 962's Avatar
BMW 3-Series Project: Coolant Pump Replacement
Anyone got any questions on the Project: Coolant Pump Replacement for your BMW 3-Series? (E90 2006-2009)
Here's a back link to the original article: Pelican Technical Article: Coolant Pump Replacement
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of:
101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 (October 2018)
Check out our new site: Dempsey Motorsports
Old 12-31-2009, 04:10 PM
Just put in a brand new water pump but can't get the bleed procedure to start. I followed the steps to start the bleeding but nothing happens. Would a bad tstat stop the car from running the bleeding procedure? I've even replaced the 40a fuse. Would I need to replace the electrical connections? If so,what would the part number be?
Old 07-09-2017, 06:06 PM
I also replaced thermostat and water pump on my 2008 e90 with the n52 engine. I’ve got the pump to bleed 5 times and still have no heat. I felt the lines going from radiator into heater core are not getting hot so does anyone have a answer to why that is? My car also does not have a heater control valve.
Old 01-12-2018, 08:05 AM
