Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E90 (2006-2012)
Ricky C (guest)
Guest
Posts: n/a
Hi, I've got a 2007 BMW 318i E90 which has got a leak from the auto transmission electronic plug at the rear of gearbox. My question is: do I have to replace the sump pan, filter and seal or can I just replace the electrosensor plug?
I don't plan on keeping the car for long, maybe another year or so but I just don't want the gearbox to burn out. On that note, is it absolutely necessary to drain and replace all the transmission oil or can I just top up as per required? It's done about 110k.
Thanks in advance for your help!
Regards
Richard
This post was auto-generated based upon a question asked on our tech article page here:
Old 10-22-2013, 03:38 AM
You will have to remove the trans oil pan and replace the Mechantronix sleeve (connector). I would repair it as soon as you can. Until you can repair the sleeve, top up the fluid to be sure you have the correct fluid level.
- Nick
