Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E90 (2006-2012)
E92 xdrive lower steering joint replacement
looking for some direction on replacing the lower steering joint assembly on a 2009 328i xdrive coupe. Part number 32306784845 . it seems held in place by one torx screw on top end and the another at the lower end toward rack. are the bolts easy to reach, does it disconnect easily from the spline, and is it keyed so the new assembly will go in the same, thank you for any help...
Old 09-19-2016, 06:57 PM
Administrator
Dmitry at Pelican Parts's Avatar
Hey Frakster...I've attached a link to our E90 tech articles that I think you'll find helpful in troubleshooting your issue. If you have any further questions, don't hesitate to post a Comment just below the article and someone will get back to you with more detailed info. Hope this helps and best of luck!
BMW 3-Series E90 (2006-2013) Technical Articles - Pelican Parts
-Dmitry
Old 09-22-2016, 11:03 AM
-Dmitry
Thank you for your help , but I can't find anything in the tech section to do with steering shaft replacement
Old 09-23-2016, 06:19 AM
