Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E90 (2006-2012)
328 window motor/regulator problem
On my 2009 328 my driver's side rear window will not lift up. I've pulled the door panel and the switch works. It also appears that the motor runs when you pull the switch. The regulator cables move alittle each when the motor is engaged but the window will not move or lift up. Any ideas? Is this something that I can fix that is a common problem? Thanx L
Old 10-13-2016, 01:36 PM
Administrator
Dmitry at Pelican Parts's Avatar
Hi L...check out the link below to our tech article on this issue (the front and rear door mechanisms are very similar). I think it'll help you out with troubleshooting and fixing the overall window issue. Best of luck!
BMW E90 Front Window Regulator Replacement | E91, E92, E93 | Pelican Parts DIY Maintenance Article
-Dmitry
Old 10-13-2016, 02:20 PM
