Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E90 (2006-2012)
ND (guest)
Guest
Posts: n/a
Thanks for the guide. It turned out that 3 of the 6 fasteners no longer work - the holes appear to be stripped :
I'd like to try a slightly bigger diameter-wise screw in there, but I can't seem to even find the measures for the originals - I believe they are part number 07147118369...
Any chance you might be able to help?
This post was auto-generated based upon a question asked on our tech article page here: BMW E90 Microfilter Replacement | E91, E92, E93 | Pelican Parts DIY Maintenance Article
Old 02-07-2017, 09:59 AM
07147118369, are the correct ones. I have had some luck using a little bit of glue in these holes to help recreate the threads inside the plastic. Just put a tiny bit of oil on the screw when you screw it back in to the glued hole and it should work for years to come.
- Casey
