The fault code is 2c24 o2 sensors interchanged I tried to swappe it but even worse after
__________________ This post was auto-generated based upon a question asked on our tech article page here: BMW E90 Oxygen Sensor Replacement | E91, E92, E93 | Pelican Parts DIY Maintenance Article |
You should check for an exhaust leak, sometimes the computer may think the sensors are mixed up due to outside air entering the exhaust stream. Also I have seen misfires cause that fault. Have you verified that all the ignition system is functioning properly?
- Casey |
| All times are GMT -8. The time now is 03:59 AM. |
