Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > BMW 3-Series E90 (2006-2012)
Bhugz2512 (guest)
Guest
Posts: n/a
Hi i have a 2010 Bmw e90 320i and I have hear a ticking noise from the front of the car and thought it was a loose brake caliper then as I was driving i have noticed that the ticking noise just comes along when I exceed 2500rpm. After a day or two of this i was driving and I lost throttle and the yellow engine failure light was flashing. When I turned the car off and tried to start it again, it just kept swinging. After some time trying to see what the problem was the guy that did my diagnostics had told me that the car had a lot of fault codes and once he corrected them he had told me that two cylinders had no compression. I have a feeling it might be the valve lifters. Please advise.
This post was auto-generated based upon a question asked on our tech article page here: BMW E90 Camshaft Position Sensor Replacement | E91, E92, E93 | Pelican Parts DIY Maintenance Article
Old 02-17-2017, 07:24 AM
I think that even with bad lifters you would still have compression. Have him perform a cylinder leakdown test and see where the leak presents itself: crankcase, intake or exhaust?
- Casey
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
