Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > BMW 3-Series E90 (2006-2012)
Adam (guest)
Guest
Posts: n/a
Hi Nick/Casey, if re-learning of limits stops is required, is the symptom a not ability to start the engine meaning will need to tow the car to garage or just a rough idle? Thank you.
This post was auto-generated based upon a question asked on our tech article page here: BMW E90 Valve Cover Seal Replacement | E91, E92, E93 | Pelican Parts DIY Maintenance Article
Old 02-28-2017, 09:53 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Honestly I have never not performed the limit stop procedure so I do not know. I have heard of may who never have performed the process and they swear they never had an issue. I believe that the car will go in to limp mode and some sort of driving will be possible. Worst case I believe you're limited to a constant 2500 or 3000 RPM. I'll post to the forums and see if another member can offer assistance who has had experience with not learning the stops.
- Casey
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
