Go Back   Pelican Parts Forums > 2- BMW Forums > BMW Technical Forums > BMW 3-Series E90 (2006-2012)
E90 turns off while driving and idle/surge while at a stop
I have an 08 e90 it's been acting up lately, where it starts idling very bad at a stop or if in park. check engine light comes on, then it goes away when I turn it off and crank it back up a couple times. It also has turned off out of no where no warning at all. When that happens I come to a complete stop put in park and it cranks back up like nothing and keeps on driving like normal .
Would really appreciate the help thanks !
Old 03-14-2017, 03:57 AM
Administrator
Luccia at Pelican Parts's Avatar
How does it act while you drive it? Have you plugged into your DME to check for fault codes? How many miles and what routine maintenance items have you replaced recently? This is the first step to go as it could be a number of things. I have seen surging, jerking type things result in an issue with a coil. I suggest to first check for codes and inspect the condition of your coils. Let me know what you find out.
Old 03-14-2017, 10:12 AM
