Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E90 (2006-2012)
aaronc1976 (guest)
Guest
Posts: n/a
This is a great write up and was planning on using it to get seats out to replace the passenger occupancy mat sensor. Before I try and tackle this job, just wanted to get your opinion. Basically, when I start the car and move into drive, about a 100 feet later the seatbelt light and chime goes on for about a minute and then shuts off. This happens every time I initially place the car into drive. It does not usually come back on again until I start the car again. There is no airbag warning light on the dash and the overhead console light is illuminated showing the airbag is not activated. The light and chime will go off if I buckle the seatbelt in. This is of course happening when there is no passenger in the seat. When there is a passenger in the seat, all appears to be well. There is no light or chime and the overhead console light turns off showing airbag is activated. I have Carly for BMW code reader and reset tool. There are no fault codes stored in the computer. I have scanned it multiple times, even tried while it was doing it, but there are no error codes and airbag light is not on the dash. The question is, could it be something other than the mat sensor and if so, what could it be?
This post was auto-generated based upon a question asked on our tech article page here: BMW E90 Seat Removal and Replacement | E91, E92, E93 | Pelican Parts DIY Maintenance Article
Old 03-29-2017, 10:36 AM
I believe that there is a weight sensing calibration that is to be performed, however I have not yet performed that operation. I will post to the forums and see if another member can offer guidance.
- Casey
scxtasy's Avatar
Installed new seat pad/sensor, now get 93C5 error?!?!?!
The passenger occupancy sensor in my 328i was broken so I installed a new seat-pad with a new sensor. Plugged everything in and now I get the error "9C35 Seat Occupancy detector, front passenger: system not yet released"
I tried clearing the error but it won't go away. Anyone know how to fix this?
Thanks!
Andrew
80 911 SC
94 RS America
13 Cayenne Diesel
06 Cayenne Turbo - Sold
03 996 Cab - Sold
Old 10-09-2018, 03:19 PM
Thanks!
Andrew
Hey Andrew - ever figure this out? I have the same exact problem. Using my foxwell scanner I get the same code and it says 'not assigned'.
Any help or info would be much appreciated!
Old 01-05-2019, 06:25 PM
scxtasy's Avatar
Hi!
I ended up taking the car to a local independent shop. They were able to clear the code using a more sophisticated scanner by fully re-initializing the air-bag system. They did it for free and just asked that I use them in the future for other repairs, so I was really happy!
Andrew
80 911 SC
94 RS America
13 Cayenne Diesel
03 996 Cab - Sold
Old 01-07-2019, 10:46 AM
