Go Back   Pelican Parts Technical BBS > 3- BMW Forums > BMW Technical Forums > BMW 3-Series E90 (2006-2012)
Michael (guest)
Guest
Posts: n/a
Does anyone know where the fuse is for the license plate bulbs? I had some errors which lead to those bulbs. They were both blown so I replaced them. After replacement they still did not work so I searched and found the wires can break under the rubber boot. I took the boot off and found two broken ground wires one to those bulbs and a few wires with stripped insulation both of the + wires to these bulbs. I re-soldered the ground wires and taped up the other wires but it still didn't work. I then got my meter out to see if I could trace those wires to the fuse box. I found where they connected to a couple of fuses that also shared other devices but all those fuses were good. At this point I am not sure what else to do so I am hoping someone can point me in the right direction. Maybe it uses a control box somewhere and that box is dead or maybe there are other fuses etc. Any help would be appreciated because the warnings are driving me crazy. I can get the bulbs to work by hooking them to something else but I want to get rid of the errors.
This post was auto-generated based upon a question asked on our tech article page here: BMW E90 Rear Light Replacement | E91, E92, E93 | Pelican Parts DIY Maintenance
Old 03-29-2017, 11:46 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Very good diagnostic work! I think in your case the shorted wires have fried the footwell module (FRM). Have seen that a few times after the trunk wiring insulation comes apart. Try clearing the faults in the module first, if that doesn't work the FRM is most likely bad. Double check the license plate light bulb output from the FRM. You can get a 1 day subscription to BMWTIS.com for $30 and download the wiring diagrams and component locations.
- Casey
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
